AFB leak down
Stumper
4:57 AM
Bandana, NC
Have a Carter 3253s on my 361 bb. Noticed for some time that after the car sits for a week or so, it gets hard to start. Within a few day window it starts easily. I just pulled the carb off after the motor had not been run in a good month or more and there was no fuel in the bowel at all.
Thoughts on where the fuel is going? No sign of external leaks.
Evaporating, or your fuel pump check valve has something holding it open...
It must be evaporating. I don't see how it could siphon out the needle valve as the bowl is lower than the inlet port.
You would lose the column of liquid.
Safest way to refill the bowls is with a squirt bottle having a rubber tube to connect to the bowl vents.
Squeeze fuel into the vents to fill the bowls and use the accelerator pump to prime the carb.
The AFB vent tubes help encourage evaporation in the bowl ps and todays fuels with so many volatiles in them just speeds up the process.
I thought about back syphoning through the filter but as noted above the inlet is above the bowl level. I use only the non ethanol 90 octane in the car but Of course it’s still going to evaporate. Its sounding like evaporation may be the problem? This is the first Carter I’ve had, don’t recall running into this with any of the Holley carbs?
I have 3 running Holleys and it does happen to them too, I can attest to that. I suspect it may leave a Holley a bit slower because it has sort of a convoluted vent passage through the metering block and out the main body through the single tube, but not sure it’s much different. Also Holleys sometime loose fuel for leaky bowl and accelerator pump gaskets.
I dont have any problem with my 850 Holley doing that. I run 92 and 93 pump. Course I also run an electric fuel pump which helps. But it fires up right away unless pretty cold out as I dont wait for the fuel pump to run long I crank it right away. Ron
Your heat riser valve isn't stuck shut?
A valley pan with a block off might help.
Also float bowls are small and directly above the hot intake. That combination is just asking for evaporation. Worse after a hot soak and today's puppy pee gas sure doesn't help.
Did that with the last several cars. Most sat for a week or two before use.Put mine on a switch to prime the fuel system,then start the car.
Something like this?
This one blocks off the heat riser port accross the intake.
When I removed the original cast iron intake off my 66 383 there was insulation under the intake.
Don't know how much that would help but it probably doesn't hurt.
I did that for years with a BB 66 Corvette I have but didn’t use it very much as I was afraid of its pressure possibly flooding everything. It was a Holley pump for carbs but I suspected it was putting out over 6 psi. But I eventually disconnected it after considering I didn’t have an interruption feature on it in case I was hit hard and the engine killed and the pump continued to run and flood gas out.
Use a momentary switch for a priming pump. Make sure the circuit is fused.
Yes, there are mini pumps. Holley has one called the Mighty Mite $50 Jegs/Summit.
Same pump with many different names such as Mr.Gasket,K&N, ETC.Many pressures including 4-7 psi and 7-10 psi for a few bucks more.
I installed a 1.5 to 4 psi on a 360 4 bbl Cordoba and for a test ran it without the mechanical pump.
Drove it around all day and ran just fine even wide open sprints.
Used as a back up,primer and such. When not running fuel flow runs right thru it without any restriction.
The electric primer pump might be the best option. Even after sitting a week I have to run the starter for a good minute to get going and I sure don’t want to have to remove the air cleaner and squirt fuel in all the time.
