Dibbons
- 7:20 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
You hit the nail on the head. LONG VS SHORT need different cam timing and profiles. The intake valve chases the piston on the intake stroke. And since piston acceleration is faster with a short rod it can stress the intake port differently. You can and need to open the intake valve more agressively with a short rod. i usually do longer rod motors with marginal heads.Engine Masters had a great show/episode on that very subject...
not really much difference in power
or "alleged" longevity either
many other factors are more valued as it comes to power
I've always had the longest rod I could get without really getting
to much into the oil rings, having to use buttons
makes for a light piston with a longer rod
short rod vs long rod
biggest difference is the time (dwell) it stays at
top &/or bottom of the stroke
& you need a camshaft that takes advantage of it too
I wouldn't really worry about it 'too much'
lots of short rod motors/engines make some serious power
Good article for street enthusiasts.Read the Isky Cams Tech Tip about rod length.
I have a custom set of small block rods that have a 6.298" length (vs 6.123" stock connecting rod length). They are standing by inside my 305 Mopar de-stroked 340 long block to be finished some day soon (see photo).
