1970 roadrunner air grabber door install question
barryv
7:44 PM
middleburg,fl
hi, i have a 1970 roadrunner that i am converting to the air grabber hood style. the airbox is mounted correctly with rubber seal. i have purchased a used original air grabber door flapper. does anyone have a close up picture how the to 2 arms that attach to the air box door mount. for some reason i am having issues. the left and right flapper arms do not reach the inside of the air box door were the pins go through.hope this was not too confusing. thanks
I did an electric conversion but maybe you can get what you need from this video.
i figured out the issue. the swing arms that lift the air grabber door are missing part of the swing arms on both sides making it to short to bolt up
