BeepBeepRR
I used assembly lube on the cam, and every lifter. Also the lifters were soaked in a tub of oil. I didn't do the oil soak. JJ soaked them. The lifters were not stuck in the bores they were just damaged too bad to pull out through the top. Just thinking it was as simple as not getting oil on the passenger side of the engine like it should. I used VR1 20-50 oil in the car. I have had no issues before now and I have installed a few cams. This 440 has had issues since the guy got the car. First the passenger side had the rocker shaft upside down. This engine came from an Engine builder in South Carolina. I did not build the engine. It has had a tick since day one. Eventually that lifter failed and the tick was not getting any better.
