Rusty 72
Hello all,
I have a 68 904 that I rebuilt and put in a 1972 Charger. I replaced all the seals, bands, and clutches. I pressure checked everything after rebuilding and all seemed good. Now I am having an issue where it will shift 1-2 perfect, but only 2-3 sometimes? It'll shift 2-3 in the morning when its cold but once it warms up it doesn't want to shift 2-3. The original KD linkage is gone and I am using a cable set-up. I checked the governor pressure and it was 0psi at idle, approx 30psi at 30mph, and 50psi at 45mph. I didn't go over 45mph because the rpms were getting up there. It's shifting 1-2 around 15mph, and when it does shift 2-3, it's about 30mph.
The fluid looks nice and clean still. Could it just be under filled? I am following the dipstick and was worried too much fluid would aerate like the book says.
Thanks in advance! Jeanette
