SOLD 440 engine with hemi parts
63max wedge
1:34 AM
wi
Feedback: +6 / =0 / -0
Rebuilded 440. +.030 bore std/std crank. the crank is a new 3.48 nascar hemi 8 bolt crank, rod new 7.060 nascar piston KB piston +030 400 piston. New comp cam .509/292 new lifter. New ring,bearing Bal. bore and hone with a torqua plate 10.3 to 1 comprssion. Heads are 2780915 67 440 HP with big valves And new spring HV oil pump 402 oil pan. Maybe one hour on the engine. The block is a 1977. $3100.00 If you pay $750-800 more Will dyno the engine. NO CARB OR FUEL PUMP.
