Heater resistor wiring
snakeoil24
5:59 AM
New Jersey The State of Tax Theives
if anyone can point me too a better diagram to wire a 2521153 im using on a ac box in a 67 coronet with 3 speed switch. I know its not correct for 67 but im going to use it. any help apricated.
I looked up the A/C diagram in my 1967 Plymouth service manual, and the wiring is pretty clear. Four wires go to switch. A low speed, a medium speed, and the high speed and motor wire which are connected together. The manuals can be downloaded and you can see which terminals the wires go to. The color codes of wires on also on the diagram.
As I look at question, you may be looking to wire the heater blower motor resistor. It is also on the same diagram.
Thank you where do I down load this?
