Adjusting Hyd. lifters
STREETREBEL
12:35 PM
Willard,Mo.
I have Crane adjustable rockers. Do I need to turn them 1,1/2?
Hydraulic? Which ones?
This ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Hyd lifters
Not all lifters are the same, in fact can be drastically different. So here is a comp instruction( and again, this doesn't take into account the different ones just from this company alone..)
With your rocker, 1 full turn is 41 thou.
I would adjust them 1/2 -3/4.
After finding out which lifter you have of course.
Not all lifters are the same, in fact can be drastically different. So here is a comp instruction( and again, this doesn't take into account the different ones just from this company alone..)View attachment 1340168
Thank you sir.
Absolutely. Depending on the lifter model (Comp's Pro-Magnums come to mind) they may require a very slight amount of preload.
Read my comments in this category under the thread 'valve Lash'.
