MoparLeo
NRA BENEFACTOR LEVEL LIFE MEMBER
- 10:11 PM
- Nov 24, 2015
- Moreno Valley, So California
It's a 69 Coronet with 440. I will check the voltage regulator, I'm not sure which model I have.What year car are you working on? Do you have the early style small square voltage regulator? The originals of these were mechanical points type, but did not work well with electronic ignition conversion. Later versions were electronic with a circuit board to work with electronic ignition. If this is the style of regular you have, one of the field terminals should be grounded. I always ground the one you have circled. This would be the reason your alternator was not charging the battery.
95 Amp. PowerMaster alternator; did you upgrade your charging circuit to 8 Ga. wire as instructions tell you to do? If you did not, this is the electrical equivalent of pushing a golf ball through a garden hose. I put the same alternator on my '64 Polara, and did the wire upgrade. There are threads on here about this. Burnt fusible link is usually a short circuit, but could be that golf ball thing.
How do you test the voltage regulator?And most likely damaged/destroyed the Voltage Regulator in the process.
Soooo, I should’ve disconnected the battery to start the car? Thanks for the sound advice.To answer the title of this thread about as plainly and blunt as can be.....
You failed to read the FSM - the part where it says to disconnect the battery before doing any electrical work.
The Fusible Link did its job by the sounds of things. Be happy that it worked.![]()
Which insulated washer are you referring to?Even though new it may be a faulty Alternator and could have the insulated washer missing, a picture from rock auto may give you the idea. It's been really bad with aftermarket parts, check your replacement parts with a fine tooth comb!
the one down the brush retaining screw, to keep the prong in place ( and insulated ) againts the brush holder. This washer is tipically replaced by a metallic one by dealers to offer a "single field" alt setup out of a "dual field" alt setup. This washer replacement becomes one of the insulated brushes into a grounded one.Which insulated washer are you referring to?
I checked, mine has both insulated washers.the one down the brush retaining screw, to keep the prong in place ( and insulated ) againts the brush holder. This washer is tipically replaced by a metallic one by dealers to offer a "single field" alt setup out of a "dual field" alt setup. This washer replacement becomes one of the insulated brushes into a grounded one.
The black plastic washer in the diagram, do u have a ohm meter to test to make sure it's not grounded, or showing resistance, should be infinite. Check that to rule it out in troubleshooting,Which insulated washer are you referring to?
Good information.the one down the brush retaining screw, to keep the prong in place ( and insulated ) againts the brush holder. This washer is tipically replaced by a metallic one by dealers to offer a "single field" alt setup out of a "dual field" alt setup. This washer replacement becomes one of the insulated brushes into a grounded one.
The component part circled is the positive diode assembly (the negative diodes are pressed in the case) and MUST BE INSULATED FROM THE CASE IN ALL REGARDS. THERE IS A THIN MICA INSULATING WASHER/SPACER BETWEEN THE DIODE ASSEMBLY, THE OUTPUT STUD/CAPACITOR STUD AND THE CASE. If the conbection is compromised, a direct short circuit connection will exist......use caution when attaching the output wire to the alternator output stud to prevent a short circuit........just thought you might like to know.....UPDATE!
I had the alternator and voltage regulator tested by a local guy who specializes in them. The alternator and VR we’re fine. He then set my alternator up for single field and bench tested it. It didn’t quite live up to the 95 amp rating by PowerMaster lol He got to 90 amps with the voltage turned up to 16V!
He also showed me what probably caused the short circuit in the first place. (See pic) The circled piece was touching the case. He also gave me some of the correct connectors for the bulkhead connector. I bought a 14g fusible link from the local auto parts store and installed it.
When I connect the battery I have 12.54V at the battery, at the starter, at the starter relay and at the bulkhead connector (fusible link). I don’t have anything at the alternator or VR. I also have nothing at the ignition switch.
Any ideas where to start under the dash? Obviously the fusible link burning caused something under the dash.
