Neat.
			That hub bearing carrier/spindle looks pretty big. Would you be able to run custom 15" steelies to get that "somewhat" stock look? Or, is it big enough that you have to run 18's or 19's?Upper shock mounts made. Lower arms boxed. Upper arm mounts modified and tacked in. Spindles are now cut and tapped for the upper uni-ball.
That's a lot of stopping power, you'll be lucky if 19's fit over that!It will need a large wheel to clear the caliper. They are huge and use a 400mm rotor.
Who would do a thing like that?Haha, now that you shown that picture I might change direction. Besides the T top I might go full convertible.
