10 inch brake spindles
qkcuda
4:42 AM
Jarvis, Ontario
All of the studs worked loose in my right front brake hub. I am afraid the holes may be too damaged to even use studs with oversized knurls. I am installing a disc brake conversion that reuses the stock hubs. My car is a 1966 Charger. Can anyone tell me what years of 10 inch brake hubs will work?
All of the 10 inch B-body front drum hubs used all the same inner and outer bearings
from 62-72 years. I am sure I have many hubs and drums with very good used wheel
studs in them.
Thanks, I may have a line on one locally. I just wanted to make sure which years will fit.
