FOR SALE 426 Hemi and 4 Speed / 70 Cuda Block
rayray50
12:11 PM
New Baltimore Michigan
Feedback: +0 / =0 / -0
$16,000 obo
I have many more Pics. Message me and I will send them.
Block, Crank, Heads are all coated in LPS 3 Rust Inhibitor
Not a complete Engine, it's has a repair in the lifter valley. You can See in the pictures.
It was ran for 5 years after the repair with no problems. I was told it was checked for cracks after the repair and none were found.
4 Speed Hemi 18 Spline is out of a 69 Charger R/T It was rebuilt years ago and put on the shelf as a back up.
Engine Parts:
Block: Standard Stock Bore 4.250"
Cast date 5-26-69
Vin On the Block: 0B201242 the car vin would have been, I'm told BS23R0B201242
Marysville number is: MN426304861317
Crank: is all ready to go no machining required.
Main Journals : are 2.750" the best I can measure
Rod Journals are : 2.375"
Heads: you can see the casting dates in those
Original Valve Covers:
Original Intake:
Harmonic Balancer and bolt
10 Rocker Rail Stand offs
Moroso Oil pan and Pick up. I believe this is for a B Body
Valey Pan and Anti Slosh plate
B/E Body Hemi K member
I was going to put this in a 69 Coronet R/T so I have everything for a 4 speed swap except the throughout fork.
Transmission: XS29L9B125796 vin
PP8332552 0060
Hemi Flywheel
4 Speed Hump from AMD
Hemi Bell Housing with original Pan
#2892259
Z Bar
Hemi Direct Drive Starter
4 Speed Pedals
Original Linkage and all new REPOP linkage
All Brackets needed for the Swap You can see in pics
New REPOP Pistol Grip shifter
New Trans Crossmember
Firewall Stiffener Brkt
Torque Shaft Service Kit
Clutch Rod Service kit Clutch Linkage Hardware
Trans Operating Lever Set
Trans Crossmember bolt kit
Shifter Mount plate bolt set
Hurst Competition Original style Shifter
3 Shift mounting Plates
*Price is of course Negotiable.*
I'm not going to split this up unless I find someone who wants all engine parts and another who wants the Trans pieces.
I'm not answering "IS THIS STILL AVAILABLE"
If it's up it's still Available
If you have nasty comments Please just keep going and don't post them.
I'm not shipping. If you want this please have a way to come and pick this up.
Cool looking stuff. Please update your ad with pricing. More pictures of the transmission spline, please. I am also curious about that patch. Thanks
SO the passenger side water jacket around cylinder 2 4 and maybe 8 has been welded up? Can you provide better picture of repair.
