front Brake line routing for 67 GTX
Pops1967GTX
8:55 PM
Monroe, New York
Manual drum brake System..Does anyone have a pic of how the front brake line routes where it transitions from brake cylinder of the engine bay to the inside of the rocker panels, frame ? the routing of the current line doesn't look right...
Let's see a pic Pops
will do, it's at a friends garage while i'm doing the clutch & going through the transmission. The previous owner routed the brake line against the clutch pedal boot at the firewall. As you engage the clutch pedal & the rod to the Z bar its hitting the brake line. I ever noticed this before. Hence I should wear my eye glasses more....
Dont know if it will help, but heres a couple of pics from my 67 Belvedere II, manual drums. Its a 46k mile car, so I think its original.
thanks you!!!!! that's the photo I need. My brake line is going over and down along side boot for clutch pedal rod, then to junction block. what a problem I had doing the Z bar until I saw problem with brake line....
You can see how the 67s are different than 69s
