Wing window issue
milit73
4:31 AM
Vacaville, Ca
I am having the interior installed on my 68 Superbee and when rolling up the window the frame on the wing window moves when getting to the top which then allows the window to have interference with the back side of the window. The guy cannot see what else to tighten. If I remember correctly he said the two bolts are tight and he sees a rod but nothing that keeps this from moving upward. The other side is solid And has not issues.
I know the description sucks but any help would be great.
I'd guess that the track "foot" is broken off at the bottom... otherwise there is only the allen key "clamp" at the top of the track (access via the little black plug) and the forward vent frame arms bolt and nut behind the two 1" plastic plugs.
I'd guess that the track "foot" is broken off at the bottom... otherwise there is only the allen key "clamp" at the top of the track (access via the little black plug) and the forward vent frame arms bolt and nut behind the two 1" plastic plugs.View attachment 1368911View attachment 1368912View attachment 1368913View attachment 1368914
Thank you I will go to the shop to check that out on Monday.
