Made some hood signals .. UPDATE.....
Canadian1968
10:43 AM
london
My 68 charger hasn't had hood signals operational for a while. Only because I had broken the ear off one of the housings so there was no way for mount one side.
I recently got interested in 3d modeling. I thought hey I could probably make my own housing . So a little time on the computer.. and few hours of printing and I came up with these..
Pretty happy with how they turned out.. still have to paint them..
Looks good, but the original metal base makes up the ground circuit for the lamp.
Your right. I realized this as I was test fitting the light bulb socket . Which is where the connection is made. So all I need to do is add a small ground lead to the bulb socket. The ground lead will be connected inner hood support cut out for the lights . I will post some pics as soon I have that done.
And this will actually be a much better and reliable connection compared to the factory that just relied on the ears of the housing contacting the hood
I might run the ground to the body of the car instead of the hood.
Very cool, keep us posted.
The hood was good enough for the ground before and with better method of making the ground I'm sure it will be fine. Plus will make for a nice easy install
If you have a stud gun (stud welder) you can make it fancy.
Well a little bit of research and some problem solving and this is my solution to the ground problem since my housing is Made of plastic.
I got some Ba9s sockets. I had some ring terminals that fit the diameter of the socket almost perfect. Test fitted with the bulbs I purchased . I then soldered the ring terminal to socket at the correct depth for the light sit in the housing at the proper location.
The ring terminal now also acts as a stop much like the design of the original factory sockets. Now you can ground the wire to where ever you please .
These new sockets are smaller so I need to alter the 3d print to make a nice snug fit.
But basically this is the finished product! I am also going to print the backing plate that sandwiches the housing to the hood as well !
Maybe not be 100% OEM correct but it's pretty close and in my opinion a better design ? Ohhh and saved myself about $350 .
If anyone is interested in a pair of these for their car PM .
Thanks.
I would have hit you up had I not purchased a pair a few years ago.
Nice job!
(Bookmarked for future reference.)
