What tools have proved to be invaluable to you?
Sky hook
Sausage roller
Bacon stretcher
Left handed smoke shifter
I never go camping w/o them!
Innova 5568 timing light - dial back timing, tach, dwell, voltmeter - all in one device. Great to have a tach on the same device to plot your advance curve while timing. Just keep the inductive pickup away from the exhaust manifold as it’s plastic and doesn’t like heat (as I found out).
Amazon product ASIN B000EVU8J8
My lift. Oh god it's a game changer!
My Wen 1/2” belt sander. I have two of them. I dropped the first on and broke the on/off switch, bought a replacement and then found I could order a replacement switch ($7) and fixed it. They cost about $38 and I use it a ton on my project car - spot weld removal, plug weld grinding, sanding hard to reach places, wood projects too.
Has (2) settings. Does a phenomenal job at lighting the engine bay. Cordless and has foam pads where it makes contact with the hood.
M18 Milwaukee. I believe 2200 lumens IIRC. Collapses for easy transport around the shop. When I brought the Duster home, the shop was still without electric. No heat either. In the dead of a NY winter. I used this as my main source of light as I made wiring repairs to the engine harness that was threatening to burn the car down when I brought it home. Chiseled away at it an hour here and there for several weeks. This light always reminds me of that time of intimacy with the Duster.
:lol:
