WTB ‘68-‘69 1/2 Dana 60 Left/Drivers Side 23 Spline Axle Shaft
6PK2GOBEE
3:45 AM
Warners, NY
WTB Dana 60 Left/Drivers Side 23 Spline Axle Shaft for a ‘68-‘69 1/2 B-Body Power Lock.
Looking for a nice complete takeout so I can just bolt in the entire assembly- bearing, flange and axle shaft.
This is the longer of the two and measures 29 21/32” from outside flange edge to the tip of axle shaft (see chart below)
Kevin
OK, dumb question.... isn't that axle the same as a common 8-3/4" axle?
They aren’t the same. I’ve seen Ebay listings that have the description they are the same(cringe!)but they aren’t.
I will defer to RemCharger on the spline count being 30 for 8 3/4 rears.
Dana 60 rears were supplied to Chrysler(as well as Ford, GM, and AMC)as a complete drop in assembly.
It is important to note that ‘66 &’67 B-Body rears were 5/8” narrower flange to flange than ‘68-‘69 1/2 and the axle shafts were 5/16” shorter each accordingly and will not interchange with the ‘68-‘69 1/2 rears when using the original tapered bearings.
The chart I posted gives details for ‘68-‘69 1/2 (23 spline).
