When the poles shift and they will shift
Some of our folks are saying a shift is way past due and some are saying it is happening now. Of course the global warming money recipients are really hyping it up at the WEF .....
All ready has taken place. I believe 2 years ago the planet shifted approximately 4 degrees on its axis and thus has created a change in our weather patterns. Funny but all the alarmists cannot see it is a natural occurrence and will always blame human kind for these things. When in the hell will humans understand that "MOTHER NATURE IS ALWAYS IN CHARGE!!!???
:realcrazy::realcrazy::realcrazy::thumbsup::thumbsup::thumbsup::usflag::usflag::usflag:
This is true, to an extent.
the people screeching about how human are destroying our planet are also:
Shooting particle beam "weapons" into the upper atmosphere to heat it in order to alter wind patterns
Seeding clouds to cause them to drop their moisture where they want
Using both of the above as a quiet, passive aggressive means of warfare.
Sounds like some tinfoil stuff I know. People will have to decide if they want to go down the rabbit hole on that.
Note: recently stories about ocean currents being interrupted have been thrown about. Maybe altering wind patterns has consequences?
The ozone layer has been healing itself
Actual science shows the time in earth history where carbon was highest coincides with the largest surface area on the planet completely thriving with life.
Human carbon emissions, even many years added together, were absolutely eclipsed by the siberian wild fires from two years back.
The original UN green new deal document is where people should go to see the real ambitions of the neo-hippies and globalist elite.
4 degrees is huge, it hasn't happened. The actual pole shift since 1980 has been only about 13 feet, a tiny fraction of one degree. A 1-2 degree wobble every 40,000 years is the usual consensus for studies of our planet.
The story I heard several years ago said we were overdue (WAY overdue) for a swapping of the poles.
SWAPPING.
