Need Master Cylinder Bolts
dspur
11:59 PM
Albertville, AL
Need the 4 master cylinder bolts. They mount from the back side with the nuts on the engine bay side. This is for 69 Bee manual drum brakes.
I suppose if could reuse these but after cleaning up from rust they are awfully pitted.
TIA
......OR just buy hardware store bolts.
They go in from the engine side and nuts are inside the car if you want to be like factory. Which is the only reason to use these studs.
Studs like that do make the master cylinder easier to install but if the hardware is hard to find, why wait?
Haven’t been able to find this type of bolt locally. May have to improvise but prefer to use the same type.
Yes that IS the reason I prefer to use these. I am blasting painting the pedal assembly - all had a good bit of (mostly) surface rust.
He sure is proud of those studs going by his price. And yes, I would definitely try to find someone else to buy from.
I have changed master cylinders, hydroboost units and brake boosters with simple bolts and nuts alone and while it isn't fun, it can be done.
$35 is steep but it sure may be worth it to the man that isn't so nimble.
