FOR SALE Lots of Mopar Engines for sale Located in the Pacific NW
FivePointParts
11:23 PM
Portland, OR
Feedback: 0 / 0 / 1
Hi There! Please feel free to ask any questions about the engines. I did my best to get the casting info. If you want build date info let me know. These Engine are located in the Pacific Northwest. Thanks! -V
1) 67 440 C440 6/30/66 Standard bore, good core out of 67 Chrysler $1500
2) 67 383 C383 9/20/66 Good core $1200
3) 71 383 HP G383 HP long block with 452 heads standard bore 7/8/70 $1800
4) 76 440 6T440 core long block 6/7/76 $800
5) 76 440 6T440 core long block standard bore 2/6/76 $800
6) 58 325 Poly Dodge Spitfire Core turns over $800
7) 72 340 complete core 5/26/72 $2600
8) 69 440 E440 long block 9/28/68 $1500
9) 72 340 w/ 518 4 speed OD trans both rebuilt engine casting 2/8/72 Weiand 8007 intake, 30 over, ported and polished heads, deep sump oil pan, lopey cam, may come with headers.. $8000
10) 69 440 1/13/69 BLANK PADS A12 candidate?? Turns over. Contact for more info.
11) 65 383 A383 1/22/65 turns over $1000
12) 71 440 HP G440 HP manifolds, dual valve springs, 906 heads 1/21/70? 71? Probably 71. Was rebuilt not so long ago $5000
13) 67 440 HP C440 rebuilt 30 over, 906 heads, adjustable rockers, 292/509 cam 1/5/66 $5500
14) 73 440 J440 Standard, rebuilt, double roller timing chain, new valve seats, 6/14/73 $3500
15) 77 400 rebuilt 10/31/77 $2500
16) 70 383 HP F383 out of 70 Challenger R/T 906 heads, HP springs, core 9/8/69 $1800
17) 69 440 E440 runner 20k miles on the engine 1/18/69 $2000
18) 69 383 E383 core 8/6/68 $1000
19) 72 440 new timing chain, HP valve springs, new freeze plugs, seals, gaskets, 4/3/72 $2500
20) 68 383 HP D383 3/28/68 Contact for more info
21) 62 361 HP core out of 62 Dart BIG HP stamp 9/10/61
22) 56 341 HEMI DeSoto Fire Dome Rebuilt $5000
23) 69 383 HP E383 516 heads, HP springs, rebuilt, 8/26/68 $3000
24) 73 440 HP J440 core, comes with 516 or 452 heads 1/29/73 $1500
25) 71 383 HP block w/ crank 8/11/70 $1200
26) 72 340 w/ 360 heads, out of 72 Cuda, rebuilt 30 over, adjustable rockers, dual springs, Edelbrock performer, low miles 6/14/71 $4000
27) 67 318 w/ 727 rebuilt 8/31/66 $2500 SOLD SOLD SOLD
28) 69 383 HP E383 rebuildable core, 906 heads, 402 oil pan, 3/8/69 $1200
29) 66 273 core 8/24/65 $500
30) 73 440 J440 valve job w/ HP springs, RV cam 1/22/73 $2800
31) 74 440 HP Cop car motor? Steel crank, 452 heads, rebuildable core 1/8/74 $1500
32) 64 413 w/ 516 heads 7/24/63
33) 73 413 Industrial motor 9/8/72 $800
34) 51 Lincoln 337 flathead V8 complete core MAKE OFFER
35) 71 383 G383 core block w/ mains 452 heads 8/21/70 $500
36) 67 383 C383 core block with mains & crank 7/28/66 $500
37) 63 318 POLY ST318 complete motor stuck 12/5/62 $500
Holy Cranksickles that is a collection. Can you post some of the HP VINS? Some are going to ask for sure.
That will have to wait until next week. If you tell me what ones you want the VIN off of that helps. They aren't too easy to get to. LOL
Need a 383 short block. Can you help?
Prefer standard. Mine wasn’t numbers matching but would like something late 68 or early 69. Also for a 4 speed
Interested in this one ... can you provide the VIN and any pertinent info please?
Thank you!
Thank you!
I will get you the info ASAP. They are located about a hour north of me, but I may be able to have that info tonight. If not, I will be there Saturday. Thank you! -V
I am searching for 1970 440 HP engine with vin 0A202426, any help will be much appreciated. Thank you
Looking like you will have to wait until Saturday. If we don't have the needle in the haystack winner with that VIN, are you still interested in an engine?
Very interested in number 12, 1971 440, what is the cast date, build date and the vin. Thanks Gary
Could you PM me pics of #10 motor? Intrested.
Hey 5 FPPs.
Very interested in 20) 68 383 HP D383 3/28/68
Can you locate the VIN stamp located near the oil sending unit at top of the block where the bellhousing mounts to the block?
PM me if you can
Frank
Feel free to ignore this piggyback query: !!
I have a disassembled 64K sonic ram motor, all parts except correct carbs. carb linkage missing. Matching original 727. I have finally accepted advice from elders here that I cannot stuff it into my 63 Sport Fury vert. What might it be worth? thanks in advance.
Hi V,
Never heard back on this one:
I was looking for the VIN and top pad info.
Thanks!
