WTB '67 charger rear beltline/pinchweld moulding fasteners
charger10
11:14 AM
idaho
wtb fasteners for rear beltline / pinchweld moulding fasteners for '67 charger.
only need the 2 front sawhorse shaped smaller ones for each side, but would but whole set if needed. 0328230923 (2).jpg
thank you, bruce
The ones in the short sections behind the door take the same ones but are "shorter". Those slide inside the channel. I had to cut these down to make them work.
was the sheet metal springie enough to hold . the orignals are out of spring metal.
I would stick with originals if possible. Otherwise, the reproduction ones work well.
