Kultin
What grease would yall choose? Ngli 2 or 3. Ngli no. 3 is the quaker stake which is brown and thick. Ngli no.2 is the modern crisco consistency.
It is for a 72 charger disc brake k member
NLGI 2 is the grade normally used on wheel bearings automotive wise.
NLGI 3 is heavier, I wouldnt recommend it for wheel bearings, it's a bit much, and will not flow as well. It is a heavier pressure grease; larger, heavy duty bearings--heavy truck etc, good, fifth wheel plates, etc, good.
Ask the lubricant supplier (brand) to check on the compatibility of mixing synthetic and non synthetic lubricants.....seek AUTHORITATIVE SOURCES RATHER THAN RELYING ON HEARSAY OR GUESSES OR "My Buddy says" ......BOB RENTONI have a question - can synthetic grease and regular grease be mixed?
In other words, if I'm going to add some - I'll use synthetic grease but there's already the regular grease in there.
