Dimmer?
dragrazor
2:21 PM
Iowa
66 Charger. dimmer switch problem? it is new, sadly we all have found out new may not work, grrr. problem is when all 4 lights are on the red indicator in the dash is NOT, but when only 2 are ON then it shows the red indicator ?? any ideas ? thanks for any guidance................
Wiring problem somewhere. Look and see where the dash light gets its feed. That wire is most likely reversed or somewhere the high and low are reversed.
Another member on here suggested possibly wrong bulb in wrong socket as the headlight non-locked socket is close ?? thank you the suggestion
