Geee
New Member
Selling: 440 Engine (no car and w/o plug wires or fuel lines), but including flex plate, balanced flywheel, factory water pump and Holley elec. fuel pump), plus 18-spline 4-spd w/Hurst Competition Plus shift linkage (does not include Hurst Shifter or Pistol grip handle in photo), Dana 9 3/4" rear with 4:10-1 gears, factory HD pilot shaft, all original to '69 Charger RT. These parts have been out of the car for over 25 years and garage stored.
Not pretty, but would be a good start for a project for somebody who doesn't mind getting dirty.
All parts need clean up, paint, and/or new gaskets, and fluids. All parts operated flawlessly when I removed them from the Charger.
Engine has total rebuild, is .030 over, with TRW 11 1/2-1 pistons. Gasket match port and polish cylinder heads with aftermarket keepers, retainers, valve guides, 3-way valve grind, Hemi springs.
Also: Edelbrock CH4B intake, Mellings HV oil pump, Milodon 9 quart pan, Hooker under chassis headers, Holley 800cfm double pumper (modified), Iskendarian cam and pushrods, Iskendarian hydraulic lifters. Has factory stock rocker arm assemblies. Engine stand included.
More info/photos on request.
Located in Carmel Valley, CA. You must p/u. I can't ship. Price for all is $4000.
