FOUND Need 67 Coronet Fender Turn Signal Wiring
65CopCar
10:25 AM
Cincinnati
Feedback: +5 / =0 / -0
I am in need of a pair of fender mounted turn signal wiring harness jumpers for a 67 Coronet. This is a jumper harness that splits out the wire for the fender turn signals. I believe it should have one yellow wire and two tan wires.
What I have is incorrect - someone put 68 fender lights in my 67 and therefore put probably 68 jumper harnesses in it, but I really don't know what these are from - these are yellow with two green wires as you can see in the attached picture. They are wrong as they splice into the parking lights and not the turn signals.
Please contact me via PM on the site.
I have seen those set-ups on 67 Plymouths where the go from the Park Lamps (which are also turn signals) and go to the fender turn signal.
In their infinite wisdom, Ma Mopar made the Plymouths and Dodges different. I am starting to believe that this jumper is 67 Coronet specific. 67 Plymouth had the fender turn signal wire built into the main wiring harness. The Coronets use a jumper - no idea why the difference. The 66 Coronets use the same concept as the 67 Coronets, but the connectors are different - those are available aftermarket.
