Four Door Satellite/Belvedere Projects
1969VAGTX
10:24 PM
Fredericksburg, VA
I have been checking out a four door Satellite a few minutes from my house that a gentleman has just sitting in his back yard. It appears to be a 68 or 69 (just based on observation of body lines from the road). Anyone have any experience restoring or modding out a four door one of these cars and have some pictures and ideas to share? I am debating making him an offer to buy the car and turning it into a "cool" street car (maybe even a bit of a sleeper). Biggest challenge I have seen in researching is finding sheet metal to replace anything that is rusted or damaged. Could use some recommendations on that as well. If I can get some pictures and talk to the owner, I will share more. Thanks.
AMD will be your friend, but you’ll need to cut the 2 door stuff to fit your crew cab.
That's kind of what I figured. I wonder if door skins are standard size even on a four door? Admittedly, I haven't gotten a close look at this thing yet, so I could get scared off if it looks too bad up close. But I have been getting an urge for a low key project that would be a fun driver.
Love my more-door.
Tons of fun, and...different. Mechanically it's a b-body like a RR, so all the go fast stuff still applies. But you'll have a body that is unique, and it'll stand out. I say, grab it.
What is different between 2 & 4 door is a relatively short list. Not the same, all glass, doors, A pillar, roof, dutchman and quarters...and to some extent rockers.
The same....everything forward of the firewall....everything. Heading towards the back....the inner and outer front door hinge panels, the floorboard, inner rockers, rear footwells, rear seat panel, trunk floor, gas tank, gas tank mounting hardware, inner and outer wheel tubs rear framerails, seat brackets, trunk lid, tail lights, bumpers, dash assembly, front door hinges, door strikers.
4 door cars are often overlooked, but they are a treasure trove for being a parts car for a 2 door. Even some of the 4 door specific stuff can make great patch panels for a 2 door.
Going the 4 door hotrod is also a lower cost approach as you can often get into the 4 door at a much lower entry price. I'm also 4 door biased.....67 Belvedere moordoor 512 stroker, mini tub, 4 speed.
Hell yea!
My '72 wagon
Born 318/904, 8.75" SG 3.23. Swapped to 360/380 crate motor, reverse/manual 727, 2400 stall. Currently an LA 360 with a "normal" 727. Waiting for me to get off my *** and finish collecting bits to install my '05 5.7 Hemi, possibly/probably with a procharger.
Newer, I have my factory-turbo 1990 minivan:
Factory 2.5 4 cylinder turbo, upgraded with an intercooler, a manual boost controller (14psi instead of stock 7psi), Shelby swaybars front and rear, quick ratio Shelby steering rack, 2.5" side-exit exhaust, and coming soon a custom computer calibrated for +40% injectors, 3BAR MAP sensor, and fuel and timing curves for up to 28psi boost.
Yeah, I like my more-doors...
Love my more-door.
Very cool. I saw a 1967 Dodge Coronet 440 4 door on ebay recently. It was all there, even the jack. The car is solid, and not eaten up with the tin worm. Small block with factory AC, Sadly though it's gone, it's probably going to be stripped of its parts, and discarded. That Dodge would be a cool 5.7 transplant sleeper/plainclothes cop car. It will end up saving some two door hardtop rustbucket, haha the project that never gets finished.
Yep.
With the B-pillars and stronger C-pillar areas, 4-doors make for nice solid drivers, especially if you add frame connectors and torque boxes.
And the value is lower, so more money to spend on parts, and less to worry about when out on the road.
You don't have to worry about the correct paint, matching numbers mafia too.
