Turquoise Mopar paint
No they are not, I had to buy mine from another vendor. I bought mine in quarts and the color is spot on but it took awhile to get. Bill Hirsch is the place to go.
My experience with the Hirsch paint wasn’t that great. Doesn’t have a great shelf life after opening, dries slowly on your parts after applying, didn’t seem very resistant to gasoline exposure. Just my experience.
Get a match for basecoat/clearcoat. It resists everything and yes it’ll hold up to the heat. If your engine gets hotter than a car hood in arizona you have other problems.
I was at a local Eastwood store recently and saw they had Dupli-Color "Chrysler Green" engine enamel, DE1619. I used Mopar Turquoise in a rattle can and it just doesn't match the way I had hoped. Not enough green IMO.
Here's a POR15 I just did
I bought the Bill Hirsch paint and it seemed too green. I even sent them a sample card that they checked against the one that they had on file and they matched.
I use the Bill Hirsch rattle cans. They go a long way because lot's of solids in the paint. Old school spray nozzles too for the win!
Lots of different colors of "good old Chrysler blue" out there. I guess as long as you don't try to mix and match, it doesn't really matter which one you use.
I used Duplicolor Detroit Diesel Green on my turquoise 68 intake. It matched the rest of the engine very well! I took off the 2 bbl setup and installed a 4 bbl. Nice mach! Readily available!
I just tinted some U-tech single stage to match. It's more or less a perfect match to the original can of the MP aerosol I had left over.
Easy for me to say as I paint for a living. But that being said any auto body supply store that has the ability to mix custom colors should not have a problem making you some.
Nice thing about the single stage Utech is it's polyurethane industrial paint, so it is tough as hell, extremely resistant to chemicals and gasoline, has no problem with the heat and has a nice gloss. You can brush it on to
