Another closure. Atco sets into the sunset.
the trend has been going the way of the dodo bird since the 70's
we used to have like 28, maybe 30+ tracks here in Calif. originally...
starting in 1947-ish
Like 9 (maybe 7 maybe) now not 100% sure,
haven't been down south in a while, heard rumors like normal
I've seen nearly 20 close since I have been going
a few were a bit before my time
sprawling neighborhoods encroaching on them
then the new people bitch & moan about noise even when it was
there a long time prior to the development encroached on them
like people living by & buying by any existing Airports
or land cost/prices all got so crazy, the owners cashed in
some or most were driven out
www.xtraactionsports.com/dragstrips/california-dragstrips.htm
Sonoma, Infineon/Sears Point
Sacramento Raceway (has been for sale for a while)
Pomona, County Fair Grounds/Autoclub Raceway
Fontana, Autoclub Speedway (? I thought they shut down)
Irwindale, Toyota Dragstrip (? not sure about that one either)
Bakersfield, Autoclub Famoso
Redding Drag strip
Lakeside, Borona Drags - 1/8th mile
Eureka, Samoa
Fontana is done and gone.
I was gonna say you missed Barona, but I see it as Lakeside (?)
And Pomona doesn't count. If I can't race there (and I cant) it doesn't count.
One benefit of electric cars is when we start street racing them there won't be any noise which will make it a bit harder for the police to find us.
I included Pomona, because if I didn't
someone here would have said;
"what about Pomona ?"
I called Lakeside, Barona (I missed spelled it, as Borona too, oh well)
Ramona :carrot: last time one of these threads popped up too
& someone :blah: corrected it too
for those that don't know
you can race at Pomona (the 2 National Events, Winter Nationals or World Finals)
if you pay the fees for registration, are a member of the NHRA
&/or if enter/register the national events &/or qualify
&/or if have 'a real up-to-date NHRA competition license'
&/or if an assigned NHRA #
(4 digit # unless you are a Professional, division 7--- here, if you're in Calif.)
&/or if you're an active member in good standings of the NHRA
&/or if your car can go faster than 11.49 et, to require the stuff
&/or if you have the proper SFI cage/certified
(proper tube thickness & number of bars) for your et/mph, with the proper padding
&/or all of the proper
'up-to-date SFI-rated/current dated safety equipment',
with no fuel or brake lines going across the firewall, a proper puke tank,
or a properly fully contained rad. overflow reservoir
all safety equipment, including tires, brakes, is in good order
even a strictly limited amount of 'rubber hoses or hose clamps under hood',
of fuel & cooling, it will be enforced...
if you have the proper safety appearal
a fire suit/pants/jacket/gloves/boots/head sock
& Nomex underwear/viser or goggles (if which is required)
&/or an up-to-date Snell 2018 or newer (within 5 years) rated helmet,
(up-to-date, 2 years) 5-6 pt SFI harness, arm restraints,
or parachute/s if the car goes over 149mph
& neck roll or Hans device (if required, in your class)
(up-to-date, 2 years) sfi-rated trans blanket or scatter shield,
Harmonic dampner, flywheel, flexplate, clutch hat, DS safety loop, :blah:
(no broken or missing) long open lugs & studs/with slicks, or drag radials
or sfi-rated 10# or dual 20# fire-system, if need be :blah:
if the car/s can even 'pass tech' (that's a big one)
the NHRA are sticklers at National events
to the letter of the rules, you need to have all your ducks in a row
(not that you don't)
& have all the proper/dated safety equipment...
(that stuff happens far more than you'd think)
I can't tell you how many times I've been behind someone
in the NHRA tech inspection line, at a National Event that has multiple violations
& can't pass tech inspection or outdated **** (a lot)
& then pleads with them to pass their car
(they won't do it, they will give you a list of what to fix & you get back in line)
at an NHRA National Event
It's not like some lax sat. Test & Tune session
or some street squirrels Bracket event wed-thur.-friday nights, local yokal deal
their insurance & job/s is on the hook
hell even the old IRHA events (& they were far more relaxed) it happened a lot
I'm sure you know all that too
