SOLD Big Barn cleanout
Skytrooper
1SG (Ret.)
5:16 PM
St. Elsewhere
Feedback: 4 / 0 / 0
Big Barn Cleanout
I have a lot of parts that I gathered,but do not have a need for. I would like to find them good homes.Actually, any home other than mine would be best.
Most is specific to 71-74 B-Bodies, butsome may fit other years and models.
Most parts would be local pickup. Too big/heavy to mail.
  1. Green hood springs $50 FOR SALE - 71-74 Charger Hood Springs Scrapped
  2. A/C heater valve $50
  3. Green automatic steering column with wheel. $100 FOR SALE - 71-74 Charger steering column and steering wheel
  4. Dash pad CORE. $50 FOR SALE - 71-74 Charger dashpad CORE $50
  5. 4 groove Big Block crank fan pulley $15
  6. Clutch type 5 blade fan. Part Number 4140063 $25
  7. 2 waterpump housings with impellers $50 each
  8. 2 alternators - rebuildable $50 each
  9. Slap Stik automatic transmission assembly with transmission hump bracket (missing U shaped bracket for transmission). $200 Slap Stik assembly...whats it worth ?
  10. Holley 1850 carb - needs rebuild. $50 FOR SALE - Holley Carbs
  11. Rear seat CORE upper and lower sections. $50 FOR SALE - 71-74 Rear Seat core SOLD
12. 3- 14'' Road/Magnum wheels with center caps. (off 67 belvedere ?). $50
Photos of things that did not have prior for sale listing (Items 2,5, 6, 7, and 8)
IMG_4295.jpgIMG_4294.jpgIMG_4293.jpgIMG_4292.jpgIMG_4291.jpgIMG_4290.jpgIMG_4289.jpgIMG_4288.jpgIMG_4287.jpgIMG_4286.jpg
Is there a part number on the 5 blade fan? Is that something you would ship?
I could probably ship the fan. Part number4140063 . .
I think the part number is on the fan under the clutch, does the clutch have a part number on it? Thank you for the response.
Also
14" Road/Magnum wheels (I don't know the difference). One is trash since PO couldn't get lug nut off...so he used a torch
comes with 3 center caps. $50
WP_001245.jpgWP_001246.jpgWP_001247.jpgWP_001248.jpgWP_001249.jpgWP_001250.jpgWP_001251.jpg
@Nirvana The part number on the fan is 4140063. The clutch, well I could not see a number. It is an Eaton clutch.
Im so sorry, I didn’t get the notification that you had responded. Can you tell me how much to ship to 95695?
Any offers on anything ?
This is a barn clean out. Come Oct 1 all that's left is going in the dumpster or being scrapped. I need the room.
Yes, only 3 center caps. There are only 3 usable magnum rims. The 4th was removed using a torch (not by me)
Last Call !!
Everything going to scrapyard on Oct 1
If you want something...let me know.
