FOR SALE Lots of Mopar Engines for sale Located in the Pacific NW
PM sent for info on 16) Thanks
Very interested in 20) 68 383 HP D383 3/28/68
Can you locate the VIN stamp located near the oil sending unit at top of the block where the bellhousing mounts to the block?
PM me if you can
Frank
So, you are looking for a casting that will be before the car build date. What is the build date?
I don't have the original block with date stamp or the build sheet. Is there another way to determine build date?
I'm not trying to create a 'numbers matching' car. I just want the engine it came with. It is all original (or restored to original) except for the 1974 Roadrunner 400 engine and 727 tranny, and the vinyl top which I removed and painted. What I'm after is the engine original to the car which is a 383 Commando. If I can find one from 8/64 - 7/65 it seems like that would be ideal, but I guess any 383 Commando would do. Again, I don't know Mopars and date codes inside and out like so many others here. I think they went 383, 383 Commando, then 383 Super Commando but I don't know the timeline. I do know the 74 400 is rated 250 hp and the original 383 Commando was 325 so that's another reason to put it back.
PM sent
32) 64 413 w/ 516 heads 7/24/63
Is there a price and pic for this motor?? I don't car about VINs etc, but I need a standard bore car 413 block with mains in decent shape. Crank would be a good bonus. TIA, Lefty71
I will be where the engines are on Thursday evening. I can get you some pics, price and more info.
Hey! I looked at the block last night. It is Standard bore and doesn't even have a ridge in the cylinder. The caps are there. He can come up with a crank. Looking at $900 for the Standard Bore Block w/ crank. Here are a couple pics....
