WTB Looking for small block cast valve covers..
icetech
10:44 PM
Macomb Mi
Feedback: +3 / =0 / -0
Hi guys, almost time to get my motor together and i need some valve covers that will clear the mancini/harland rockers on trickflow heads... Not sure what will fit but i assume M/Ts would.. Hoping someone has a good deal on stuff gathering dust :) thanks
Also looking for a crank pulley for small block with PS
Did you find what you needed . I may have a set.
Not yet, kinda gave up and was going to order some stamped steel cheap ones.... for some reason most guys with alum valve covers literally want more for them than they cost new which is odd to me :)
ill double check when I get home. I know I have some finned cal customs
I have these but I don’t know if they’d be tall enough. They are similar to stock height but without baffles they may work And I’m local to you. They have never been used and in fact the castings are still a little rough but would be easy to smooth out and even polish.
I might be interested in those, i need to put the rockers on again.. i only had 1 rocker on the other day to measure pushrods but i swear the part of the rocker towards the intake almost looks like it's too far out and will hit anything i get.. need to make sure i didn't get something wrong.
Message me if you want to discuss.
