70 rr restoration help
Beep!Beep!
12:16 AM
Levels wv
Hi guys I'm starting assembly ,I need some help, pictures of bolts and clips etc to install quarter window it's all in one piece, and the front glass, vent window. I also need a measurement of where the running birds go on front fenders. Any under hood pictures of empty battery tray and engine bay 440-6 before and after engine. If there's a good build documentation on sight a guide to their build would work well. Thanks to all.
Look up DadsBee one of the most documented and photographed restorations I have ever seen. Different year but most should apply to your 70.
I have these from a 70 Bee.....should be the same
2 with 1/4 cut away, 2 inside
Mine's a vert so quarter window stuff will be different. I have a build thread focused on engine bay for my daughter's all original 69 Charger RT (440) at link below. As noted earlier a lot of the engine bay will be similar.
My Daughter's 69 Charger R/T
Ok thanks so far ,I have a set of wiper transmission arms and the #30191 part that comes through the cowl ,will this work on my 70rr?
