426 Hemi Motor mounts
Jamesman
New Member
7:17 PM
Edwardsburg, MI
Hello,
New to this site.
Pulled engine out of my 66 Hemi Satellite.
Installed new correct motor mounts.
Driver side is specific for 66 year.
RH side same, all 426 Hemi
Inserting the motor with the Pass. RH side installed
I am a good 1" away from the Driver side lining up
with the vertical bolt hole.
Scratching my head why?
Any suggestions?
James man
Picture would help. Once I put passengers side rubber on backwards maybe that's the problem. Turn it 180* and try again. Think that's your problem. After finding that spent sometime. Just turn rubber mount.:BangHead::BangHead::BangHead::BangHead::BangHead:
Good luck, welcome to FBBO
mounts on the wrong side of the brackets or block mt ?
When you turn it passengers side rubber insulater it will move forward or backward depending on witch way have it. It can be put on either they didn't make it so it only goes on one way.
Hello,
New to this site.
Any suggestions?
James man
Welcome!
