Adding PS to a Gen II Hemi ?
VANDAN
12:36 PM
Western NY
After finishing my '63 MW project, I'm looking ahead to my next money pit, a '65 Coronet Sedan. My '63 is bare bones, No Power steering, or brakes, just that big ol' wheel to crank on, to get it parked, in those tight spots. Thinking of adding the P/S to the Hemi for the '65. Has anyone completed this changeover, and what will I need ? I'm guessing the gear box, p/s pump, and is the steering column different, in length possibly ? Would I need the correct year pump, and would a B/B pump work, say from a '65 383 car ? I've got some time on this, but would like to gather the needed parts. Thanks for any, and all info...
You can use an b/rb pump and brackets on the Hemi. Get a gear box and what ever hoses you will need depending on pump and gearbox fittings..
Maybe consider an electric power assist steering column instead of the usual hydraulic power steering. The electric power assist steering is available on some newer vehicles. A buddy is adapting this on his 64 max wedge Savoy. There is room under the dash to install the pieces.
i love mine, works great, no hydraulic oil and hidden under the dash. gps operated out of a 2007 saturn Vue.
My 65 is not done yet but I'm using a Borgeson box that I got from Peter at BAC, one of our sponsors. My car is an original p/s car. My updates include an Indy low deck all aluminum wedge. Same block they use for the Hemi. No clearance issues, actually better than the stocker. The pump I'm using is for a 99- Jeep Grand Cherokee. It's part of the serpentine drive system I got from Jerry at SD Concepts some years ago. If you want to go Borgeson, contact Peter. There's more to it than just the steering box.
Electric assist for a stock manual steering box???
You mean the 7 turns lock-to-lock 24 to 1 ratio??
Uhh no.
For the hearing impaired……
N O !
I appreciate the input from all. Thanks. Looking for details about steering column length. Is manual different than power ?
1 finger steering ! lol, try it u will like it. best mod i did to the entire car,,i wish i would have known about this long ago...otherwise known as,,Hot rod power steering, summit even sells kits now. i built this 1 for a fraction of what they want.
