Anyone know of a 1973-74 Road Runner Satellite Grille/head light bezels install kit?
QuickBpBp
12:04 PM
SE PA
A quick look online shows nothing. Does anyone know of a good kit for the plastic pieces that the grille bolts to and that they headlight bezels screw to. I think I can come up with enough screws & bolts to install but those with plastic pieces are brittle.. I will buy a whole kit if it's good.
Thanks in advance.
As with any reproduction parts, these nylon pieces that bezel screw screws into is "close". This is was the only vendor that I could find a few years ago that had these types of inserts. I searched my local Napa and car quest stores and couldn't find anything.
Thanks Ron that is why I asked sometimes things that are so simple turn out to take the biggest effort… Appreciate the info..
Have to tried R/T specialties ?
Looked online with R/T specialties no luck, will have to call. 521 Has nothing, only showed 71 RR grille install kits and a 72 kit and like most things these days they are out of stock.. I still have to check out Ron M place he posted when I get a chance.
I bought a whole bunch of different ones from NAPA off the shelf. Some NAPAs do not have them where you can look at them yourself, so you have to look for a good NAPA
aveco has the plastic inserts they also have grille screws they are the wright wire size washer is correct the bolt head is 9/32 instead of 5/16 i checked a lot of venders this was as close to original
