FOR SALE Big Block Exhaust Manifolds 67-69 RH & 70-71 LH
Road Grabber
2:40 PM
Sarasota Florida/NY State
Feedback: 19 / 0 / 0
To the best of my knowledge the left is 1970-71 and the right side is 1967-69.
Sold as a pair or separately
$225 EACH plus shipping
Original NY State
Maybe, but doubt the factory would mix the years of manifolds.
the RH manifold you have is 1967-69 and the flange angle changed on the 1979 RH manifold. So an H pipe wouldn’t fit from either year 69 or 70, and a 383 would need two different years of headpipes.
it could be done with the right pipes or custom h pipe.
So the RH is 67-69 & the LH is?
Thanks for jumping in
I can edit the post once I know for sure
LH is 70-71
the 70-71 RH is he same size as the 67-69, but the heat riser shaft is turned 90 degrees and the bolt holes are positioned differently. So it fits in the car, but not the same headpipe.
LH is 70-71
I see. So it would work if you didn’t use an H pipe or had a custom exhaust flange?
Or take and H pipe, cut and rotate the flange perhaps?
