Ground straps
pumper1
New Member
12:13 AM
minnesota
How many ground straps on a 1964 B body. and where are they located?
I imagine engine to body (firewall), extra ground to body from negative battery terminal. I have 67 B body, and i put extra grounds on the ecm, voltage regulator, extra ground on the steering column, and ground straps from the dash to the a pillar. Can't have enough grounds
1964 with battery in normal position in front has the negative battery cable to block. A ground wire from rear of block to firewall.
The dash is bolted to the cowl with 6 fasteners that’s plenty of grounds there.
The factory had a ground wire from dash to the column in 1967. Unsure if 1964 has that.
thank u
