Intake casting numbers (Factory Hi-po)
UrbanXX
7:38 AM
Knoxville TN.
66-71 426 Hemi Alum. 2780543
69-71 440-6 bbl. Alum. 3412048
69-71 440-6 bbl. Cast Iron 2946278
70-71 440 Cast Iron 2951736
70-71 383 Cast Iron 2951666
70 340 Cast Iron 3462848
68-69 440 Cast Iron 2806178
68-69 340 Cast Iron 2531915
This has been researched many times by me and I have always found this to be correct.
Note that the 69-71 440-6 Alum. and Cast Iron intakes were both used 69-71. The Cast Iron intake is much more rare than the Alum. Urbanxx
I notice no 68-69 cast iron 383 intake.....what's the difference between those and the '70 ones?
A383wing,
I think the difference between the intakes beside casting numbers are:
68-69 Used Carter carbs.
70-71 Used Holley carbs.
So the carb mounting hole spaceing are spaced different.
If I'm wrong on this someone correct me.
Carb spacing holes are the same, but the intake needed a little more space for the accelerator pump on the Holley.
69-71 440-6 bbl. Cast Iron 2946278- This intake actually didn't appear until 1970. The first few (number?) of 1970 440/6 packs had the 1969 aluminum Edelbrock intake like the '69's did.
So is this a Cast 340 hi-po intake I assume any idea on what it's worth canadian guys I have chance to buy it jw if what there worth
Nice intake, throw the chevy tstat housing in the garbage, 150 bucks .
Is it from newfoundland
