Orig69
- 7:57 AM
- May 16, 2021
- Toronto Ontario Canada
Those look like the original exhaust manifolds.
Is this a movie shoot car? ....or Safari car?
I read about his car.. Think the guy's name is Brian. It's a FAST car so ALL stock appearing on bias ply tires...WoW!!
I wonder if she's tubbed? The Duster?
After closer inspection I guess not.
Is your point no way with stock exhaust manifolds. Could it run that 10.39 with nitrous. The 60' doesn't seem that fast seems it happened later. Or a time slip with F340. This is question, agree that car can't go 10.39 stock exhaust even if they opened exhast manifolds.Those look like the original exhaust manifolds.
It's a small block. don't think you can get much more than 410 cubes?The motor is probably just shy of 500" .
And I wouldn't go around those pits talking about nitrous![]()
410 cubes for us guys with tiny little pockets maybe.It's a small block. don't think you can get much more than 410 cubes?
No Nitrous. 60Ft times are because he is still driving the car off the line and I would bet he is using a launch controlling timing computer. It's also through stock manifolds and through full exhaust. That time slip was not at an event so it doesn't count but he did do this at an event and it does.Is your point no way with stock exhaust manifolds. Could it run that 10.39 with nitrous. The 60' doesn't seem that fast seems it happened later. Or a time slip with F340. This is question, agree that car can't go 10.39 stock exhaust even if they opened exhast manifolds.
