Splush
Some of you may have seen a couple of my previous posts. I bought a '66 Coronet vert this fall. It currently has a small block, 4-spd. The car was originally a 383, 4 spd car. I was able to find a '66 383 to install this winter/spring. This will be my first BB Mopar build. Currently the engine is bone stock, original cast iron intake, exhaust manifolds, etc. I do not have the specifics of the internals as the person I bought it from pulled it from a project car., I did hear it run. I am looking to freshen it up before I install it in the car. I would like to possibly change the intake, headers, electronic ignition and a mild cam. I am looking for a little bit of "thump" and add some torque on the low end as I am running a 3:23. After reading countless posts on FBBO and endless internet and youtube searches I thought that I had decided on a Whiplash Cam from Hughes. Before making a purchase I reached out to Hughes with a couple of questions. The gentleman that replied said that the Whiplash may not be my best option as the earlier 383's are higher compression and I would not be able to run on pump gas. I thanked him for his response and told him what I knew about the engine, nearly nothing, and asked if he had a recommendation. His response was that while I could make a guess, without more information he could not. So, I am asking the hive mind for recommendations. I really hope to get the swap done before {consistent) good weather here in the Bluegrass state. Thanks in advance.
