thehemikid
Originally a /6 3spd manual.
You guys that are running a BB 4spd in your early wagons, are any of you using the 626 bell housing? Ive mocked up a BB motor, 626 bell, & slip yoke trany, combo to see what issues I'll run into. Try'n the 626 because that's the only spare I could find in my stash that has the 4.80 bore.
Car has a late 60's K, so I know of the 1-5/8' difference. I removed the motor mounts and brackets to ease crank centering in the bay because of that. When I line up the ball studs (front to rear), the shifter mount bosses appear a bit to close to the cross member. I figure if I had to, I can fab a plate to relocate the ball stud on the bell, but not going that route yet.
Is there another 143 tooth bell that locates the ball stud a little farther back than the 626?
Also, borrowing some pic's from the /6 site iirc, appears the adapter plate I have marked 3 may help the sifter issue some, I'm not sure yet on that till the ball stud issue is settled, same with the trany mount.
Also,... the competition plus's rear shifter throw limit bolt says the motor need to be farther forward.
...yeah I know there were BB 4spd from the factory that just bolt in,...I don't have those parts.
