'66 Charger / Coronet center console interchangable?
jmbass98
11:12 AM
United States
Will the center console lid (pictured below) from a '66 or '67 Coronet fit on a '66 Charger?
On a Charger that cover is replaced by an arm rest that opens from the front.
Also Charger's have the machined aluminum top plates over where the ribbed centers are...
And completely different bracket guts to screw the stuff on.
But yes if you swap everything, you can physically bolt it on. I had a 66 Charger Armrest in my 69 Coronet 500 painted outer panels black and found some wood grain contact paper to cover the small panel with the release button and it looked like it belonged there
Yes you could build whatever you like.
Yes, if you switch the required parts out (as stated previously). Is a nice look.
