Vin location
Pjrenu563
2:09 AM
Nampa Idaho
I have a 66 Satellite that I need to verify the correct vin as the vin tag was removed for painting and I have three different vin tags. I bought someones project and they are certain of one of the vin tags were off this vehicle. If they don't match i can get my money back or do a lost title and wait three years for legal ownership so I know its not stollen.
Vin tag on the door pillar, or fender tag?
pick the one you like and get a title, provided you have an actual VIN tag......... without a fender tag AND a build sheet there is no way of knowing
The fender tag engine size should agree with the VIN.
That's a start.
But, no only VIN is on the VIN tag.
Buildsheet has one.
it wont be on the fender tag
Had to ask, collections of fendertags are common, but a stack of vin tags?? Lol
Trying to make sure the OP is on the right page.
The only two ways you'd know if you have the correcdt VIN tag...
Example.. I can't find where I stored mine for the '66 right now.
Long shot.... look at the rad support, engine side , near the battery tray for a cert card holder.
May get lucky and gave one still stuck in there.
Three ways! Forgot about the card as well. Have mine for the '66 HP2 and Wife's '67 Formula S
If you have an anti freeze sticker on drivers side before go down, on radiator support, remove it. There are numbers some numbers will be on fender tag. Look at lower left corner for SO the numbers on radiator should be there. Maybe only last 4 or 5.
