742 case with 3.91 gear - Manufacturer Recommendations
Heat-Med
11:38 AM
Wisconsin
Hi all,
I have a 68' Coronet RT with a 3-speed auto. I am looking at upgrading my 3.21 sure grip to a 3.91 ratio. I have been looking on line to find a third member, but there really is not a lot out there. I am thinking about just going new, so that I know what I have. I am looking for a recommendation of what manufacturer to go with or stay away from. I am hoping to get something that I can just bolt into my existing axel and not have to mess around with switching other things. Ideally, finding another 742 case with 3.91 would be my desired pathway. Note: I mostly travel in town, or a maximum of 45 mph. Any advise would be appreciated. Thank you in advance. And, I am looking to put BF Goodrich P27560R15 tires on the rear tires, fyi.
Guy
You have all the right stuff in your car now, except the gear set you want. I suggest you buy a bearing and gasket set and a 3.91 gear set for your 742 case from a reputable supplier like Dr. Diff, and have someone set it up for you to reinstall. If you don't know anyone that does this locally, I'm sure Dr. Diff can handle the whole job for you.
Thanks for the suggestion. I am looking to be able to swap my 3.21 back in if I want to go on a cruise at some point. Having a second member gives me the most versatility.
Timken bearings are my favorite.. I believe Cass at Dr. Diff is one of the go to guys around here. Gears — idk I have old Richmond's that were good for me or oem gears.
Just make sure your convertor isn’t slipping all the time.. otherwise stuff gets too hot.
LOL !!! You'll never do that !
I am thinking you are correct, haha. I intend on putting the 3.91s in and that is probably where it will stay. We were thinking of doing a 2500 stall behind the mildly built 440. For convenience though it would be nice to have a direct swap out.
As far as swap out is concerned 741, 742, and 489 are direct swaps in the 8 3/4 housings as long as everything is stock.
I have what you want, but I'm not going to turn this into a for sale ad. Shipping would probably kill any kind of deal anyway.
I am thinking they will be find around town, rarely go over 45 mph. As well, with the taller tires, that should make it more tolerable. The close runner up was 3.55s
In the '80s 4.10s were pretty miserable. Nowadays 4400-4500 rpm to get passed by almost everyone is annoying.
