Sixpactogo
I think you are correct in your car more than likely didn't have a fusible link. Not sure when they started putting them in but maybe closer to mid 60's.This is a great - simple diagram. Thanks. I will note that my car does not appear to have the fuse-able link between the relay and amp meter, unless it’s under the dash and I just haven’t seen it.
I know my 60 Dart does not have one and my 65 Fury does. My 60 doesn't even have a fuse box for that matter. I like that simple diagram because it basically shows which wires are hot all the time and which are hot in Accessory and ignition mode. Good luck in tracking down your problem.
