Late B Body Big Block Spool type conversion mounts for a Gen 3 Hemi
m79ded
10:41 AM
usa
I have a 79 Magnum XE that I swapped a big block into many years ago, but also doing that with a 74 Charger Big Block K member so that it all fit the 440 correctly. Now I want to put a 6.1 that a recently acquired and although there are conversion mounts from a Small block to Gen3, I have yet to see one for a Big block Spool type to Gen 3. Anyone aware of any? also aside from headers what are the best manifolds to use in terms of fitment and performance. Thanks in advance
Ok sorry I didn't read your post correctly. That said, I think that the K frame is the same between big blocks and small blocks with the difference being in the mounts themselves. I could be wrong but it doesn't seem to make sense that there would be 2 different K frames but I could be wrong.
I know that in previous A, B and E bodies there were PN differences between the various engines with regards to the K frames but with the exception of the /6 and the 426 Hemi the K frames would take small or big blocks, I put a lot of 440's into 318 cars over the years.
Unlike the 66-72 B-body K-members that fit SB and BB not including the Hemi the 73-up B-body platform has a BB and a SB k-member along with a BB and SB passenger side inner fender.
I'm in the same boat. 73 Charger with BB K frame. I have found nothing either. I am fixing to source a SB K frame and get this build going.
I was thinking the same thing or I have a buddy that can copy the SB K-member mounting positions this way avoiding lengthy K-Member swap. Either way let me know what outcome is Thanks
What was different on the inner Fender? I put in a "B" K-member years ago in my 79 that originally had a Small block and after doing so everything fit like a glove.
I'm going to take Big block spool mounts and cut the top portion that bolts onto the the 440. I'll bolt the bottom onto the the K-member make a mounting pad on the 6.1 and then lower the engine and do fitup and tack it and then properly weld and re-enforce it, Similar to conversion mounts What you think? should work I hope LOL
