Bbody4speed
Getting my 63 Plymouth ready to go to alignment shop after upper and lower control arm and tie rod end replacement. The previous owner put the new control arm bushings in it, and said that he marked the cam bolts before disassembly. Trying to get the toe set close to where it needs to be. Steering wheel turns 6 turns lock to lock. With the weight on the suspension and the steering wheel centered, I set the drivers side straight in alignment with the back wheel then I adjusted the passenger side in until about 1/8" toe in was achieved. What I end up with is the drivers side tie rod assembly being about an inch longer than the passenger side. I can't seem to figure out why. I popped the center link off of the pitman arm just to confirm lock to lock. 6 turns exactly. Then I decide to pull the pitman arm off and I can't seem to get it off, using a pitman arm puller of course. It started stripping threads on the puller. (Perhaps not the best puller made) but should it be that hard? It seems like what is dictating drivers side tie rod end length is pitman arm position. Could some one have jammed it on there in the wrong position. Should I just not worry about it as long as it can be aligned?
