- 10:01 AM
- Jan 29, 2018
- Midland Ontario, Canada
Thanks, interesting that even as the first car.. .with a B30 SPD like everyone else, that they put a 12/69 door decal on it !
You should start a Wanted To Buy "Other stuff" advertisement - Other Stuff For Sale / WantedI understand that there are some original sales brochures with my car in them. Evidently it was a show car. I know they’re expensive, but I would like to get my hands on them. I wouldn’t even mind if they were re-pops. Can anyone help me with this?
Perhaps as a mule, it was not expected to leave the factory until after many had already been dispatched - as some sort of comparison to check production cars with.Thanks, interesting that even as the first car.. .with a B30 SPD like everyone else, that they put a 12/69 door decal on it !
Got itYou should start a Wanted To Buy "Other stuff" advertisement - Other Stuff For Sale / Wanted
This discussion thread is not the place to buy, sell, or trade for parts.
As I've noted numerous times, EVERY Superbird got an SPD of B30.also SBD B30
YepAs I've noted numerous times, EVERY Superbird got an SPD of B30.
I don't find it unusual that there is no "Gate" number on the fender tag for this car. After all it is a Pilot car. Someone in assembly line planning probably brought up 1. how and when the back window plug would be put in, 2. how mixing the Dodge front components would fit on a Plymouth car, 3. when things like the wing trunk under side braces would be put in and if these would be assembled on the rear quarter panels before the body was slammed together in a "Gate." One of the purposes of a Pilot car is to assess and expedite assembly of the cars to follow.
Someone was probably doing some pre-planning since there is a B30 #.
It would be interesting to see if the next 4 Pilot cars had a Gate #, then if car #6 had a Gate #?
Which "Gate(s)" the cars would be assembled on probably was probably being determined by the first few Pilot cars.
It would also be interesting to see the "Sequence #" or lack of, is on the first 6 cars: 5 Pilot plus first regular assembly cars.
kiwigtx,View attachment 1632493
First red circle shows order of cars by supposed actual build guide - timewise.
Second circle shows actual shipped date.
You can see that the #6 car was 6 days later than the #7 car. So that suggests a bit of re-jigging of the process.
First car actually shipped appears to be the #3 car.
At least that's the info I have.
First page of the 1920 Listkiwigtx,
I believe what you should be looking at is is the “Product planning technical services fleet engineering “ document put out by Plymouth in 1969. On line it has been reorganized many times by many people. Which is all good for some purposes.
However, the original document organizes cars by the order that they were received at Clairpointe. There are 1920 cars on that list. Without belaboring; some cars are missing, doubled, and whatever on that list. But that list is the basis of all other lists
done in the last dozen years.
The 1920 List is organized as they were received by Clairpointe, not as they went down the assembly line at Lynch Road. We’ll doughtfully never know what order the cars were built at Lynch Road. Car #3, RM23VOA149846 with a J# of 97004 could have gone down the Lynch Road line before Car # 1 with a J# of 97009. But car#1 was received at Clairpointe first.
A white exterior color car probably made sense as the first car since the mix of enamel and lacquer paints would be less noticeable to mismatch for press photos.
Thank you.....that is all great information. I was just showing what I had seen in the hopes it might help.kiwigtx,
The 1920 List is organized as they were received by Clairpointe, not as they went down the assembly line at Lynch Road. We’ll doughtfully never know what order the cars were built at Lynch Road. Car #3, RM23VOA149846 with a J# of 97004 could have gone down the Lynch Road line before Car # 1 with a J# of 97009. But car#1 was received at Clairpointe first. Car # 1 was likely the test fit car for all that followed. From the documentation that was put out in 1969 there was likely a Body in White car too. So that could have been the test fit car and the 1st Superbird.
B30 must have been decided upon as the cut-off date for entry into the race homologation so the cars could be used on the track.Someone was probably doing some pre-planning since there is a B30 #.
I'll have to ask if the owner has the sheet/If the Detroit, Chicago, and NY Auto Show Superbird were in fact the same car, it would be nice if the Broadcast sheet had the “Show Car Finish” box checked. Rather than the “Mess this one up like the others” documentation.
