Low compression on rebuilt 440
Moparmayhem
11:38 AM
Michigan
We have a rebuilt 440, .010 over new pistons and rings, with new heads, lapped valves, mild cam, and hyd lifters.
We rebuilt this a couple years ago, (I know, not a good thing) and kept priming the engine with a drill to keep everything oiled.
It is now mounted on our run stand and getting ready to fire it up.
We checked the compression by turning it over by hand and are only getting around 50psi.
I'm hoping it's because the rings aren't seated yet and the lifters have bleed out the oil we primed them with originally.
Can the installed lifters be primed somehow, or is that just a running fix?
Any help / suggestions is appreciated.
Thank you in advance
You just prime the engine with the drill, hand rotate a few times, then fire it up and break-in the cam.
compression check turning it over by hand? Have you tried checking it while using the starter?
Yep we just got it mounted on the run stand, turning over by hand, starter coming soon and currently looking for a flywheel to get it started.
We were curious and just wanted get a first check.
Yeah that's what I will do is wait, might be pushing the "Oh Sh*t" button a little early.
Thanks everyone
I'm guessing the results will be a bit different unless you can crank it over at least 200rpm by hand.
Cranking pressure is a function of compression ratio, cam timing, and cranking speed. Changing any one of these three will affect the number. As long as the cam is installed correctly and the numbers are even it is what it is. No way you would see anywhere nomal numbers turning by hand.
No carb on it yet.
Alright, That's what I was thinking but wanted to be sure, I feel better, now I can't wait to here it for the first time. :drinks::praying:
The sad part is going that long and that many rotations wiping all the cam lube off. "Pre oiling" doesn't resolve that.
I'll be doing this in a month or so. I've thought about taking an old torque converter and cut off most of the converter so that only the ring gear and fllexplate mounts are left.
Anybody try this?
