FOUND Dash Emblem clips 71 B Body
Skytrooper
1SG (Ret.)
6:08 PM
NY Finger Lakes
Feedback: +4 / =0 / -0
Hi,
I am looking for the clips that go on the 3 posts of the dash emblem.
Does anybody have these or can point me in the right direction?
If they are the slightly tapered posts similar to the body emblem those are just a self cutting sheet metal nut.
Can you put up a picture of the emblem?
Looks similar to this and goes on the plastic pins. A good hardware store should have them..
They are called Barrel Clips or Tubular Nuts
The exact size , good question
Look like these
Thanks for posting that and You are right I was thinking they were the same for the horn switch pads and steering center emblem.. Brain fog moment. That said I ended up using the above clip I posted as it was easily found...
Tony D sells the reproductions with those clips... Maybe see if he sells separately..
71-74 Plymouth Road Runner Dash Emblem. NEW!! 1971 1972 1973 1974 Mopar | eBay
Yes, I need the barrel clips !
Don, the ones I am looking for are in the first column, 3rd row....two to the left of the one you circled.
It’s Brett… A Good hardware stores should have those..
